Go to AdvancedFactors.
Ask their recommendations.
Has anyone imported a full set of Delphi air springs for a D3 from the UK?
If so. Where from and how are they performing?
Is Delphi still the manufacturer for Land Rover air springs?
Sean
Yes I have. Full set (front and rear) - Island 4x4. Seem ok so far (about 40K)
They were advertised as Delphi but had no marking on them when received.
Matti
Same but mine were from Duckworths.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
 Wizard
						Supporter
						Wizard
						SupporterI got rears from the UK for my D4. They had Delphi marked on them and the box but they were for a D3, not a D4. They were actually softer than the D4 ones that came off at about 160,000km, much of that on rough roads towing. I had to swap them out for OEM D4 shocks, which were much better and are still good at 270,000km, because I didn't like the wallowing effect from the rear.
Bob
 Swaggie
						Swaggie
						I put up with a set for 40K kms before they became too sloppy so fitted genuine D4s again. However initially they were better than genuine D3 shocks after 70K so depending on expected use they may be satisfactory.
