Thread: carbon pile battery tester
    Sep 2012
    Adelaide Hills
    any recommendation or tips for buying one?
    im thinking 1000amp (500 too small)
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Aug 2010
    Sunbury, VIC
    Yes, for anything bigger than a car battery a 1000amp unit would be required. While I'm sure cheaper knock offs are available, we've only ever used the Durst units.
    We use this one - http://www.durst.com.au/DataSheets/BT-3006M.pdf but at over $2000 not exactly a home handy man unit. We use this at least 3 or 4 times a day at work on both 12 and 24 volt systems so worth it though. We have over 100 bits of plant run through our workshop each day and anything that doesn't crank like it should gets tested - 90% of the time it's just a battry isolator or something been left on and a charge of the battery sorts it, but we still go through about 300 batteries a year just in our small section.
    Sep 2012
    Adelaide Hills
    all the batteries i have are between 600 and 900cca.
    im thinking of going with a PROJECTA BLT300, $405
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Aug 2010
    Sunbury, VIC
    The CCA rating and the current potential of a tester are 2 different things. A 960 CCA battery can be tested with a 500 amp tester (well a Durst unit anyway)
    This unit - http://www.durst.com.au/DataSheets/BT-2003F.pdf - will do 1000CCA.
    Sep 2012
    Adelaide Hills
    cheers. i was just reading that. a 500amp unit will do me fine then.
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
