It would be prudent to fit the Llams loop-back plug to remove its signal processing from the system so that correct diagnosis of the cause can occur. Perhaps 1 height sensor is causing the whole side to be higher or lower than it should be.
I've noticed the car looking a little lop sided yesterday.
So I measured from the concrete to wheel arch on all 4 wheels.
Passenger side is sitting 20mm lower front & back than driver side.
I haven't investigated fully yet but any thoughts would be appreciated.
Cheers Vin
2025 D350 Defender 110
 Swaggie
						Swaggie
The loopback plug effectively removes the LLAMS module from interacting with the car's electronics.
So you unplug the wiring loom from the (black box) module and plug the loopback plug into the plug you just removed from the module. See pic
David
Everything is easy when someone else is doing it
MY14 SDV6 SE Corris Grey
Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
 Swaggie
						Swaggie
						Attach the loop-back plug to the Llams loom instead of the black box (module) to exclude Llams electronics.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberDoes the OP have LLAMS?
2007 Audi RS4 (B7)
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberAh can’t see that from Tap. Soz
2007 Audi RS4 (B7)
So I should have the loop back plug? I best have a good look.
Vin
Cheers Vin
 Swaggie
						Swaggie
						Yes, you should have one but if not then PM me your address and I'll send you one.
