Thread: GOE Heigth Sensor Rods
    Nov 2017
    Want extra clearance on my new Discovery.
    Has anyone tried the GOE height sensor rods on the Discovery 2017. Sound good for the Disco 3 & 4, but will they work on the Disco 5??? If so approx. how much extra height was gained?? Thanks for your valuable insights
    Wazza
    Dec 2011
    Bundeena
    Have you looked at LLAMS?
    Llams PTY LTD
    Contact user "Graeme" here on the forum. I believe he has or is close to releasing an update for his product to work with the D5. IMHO it is a much better solution than rods.
    Sean
    Oct 2014
    Llams for D5 is available, I’ve seen it on at least one. Don’t know about rods but agree with Sean re Llams being the better way to go.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    NSW SW Slopes
    The D5 Llams kit is available. It requires a permanent 12V power pickup either by running the supplied long wire between the pedal area and the fuse panel behind the passenger glove-box for which I don't yet have instructions or pictures, or by connecting to the permanent 12V power wire for the electric brake controller that plugs into the socket just above the pedals.
    When used with normal height, medium raised height equates to the higher speed OR1 height and high raised height can be configured to be either around 60 mm or the full slow speed OR2 height, the same as is available for the L494/L405 kit although 60 mm becomes around 54 mm on the L494.
    Nov 2017
    Thanks Guys for pointing me in the right direction. Will need to find more imho AND Llams as have never heard about them. Any recommendation in a Brisbane installer??
    Warren
