Results 1 to 10 of 16
Thread: Which rear Hub?
    Dec 2015
    Which rear Hub?
    Hi All,
    I finally got my S1 registered last month, full NSW rego and already have done over 1000 miles just running around, it was last registered in 1991 as JOC 330 and if anyone has any info about its history it would be much appreciated.
    Anyhow as to be expected a few niggles have surfaced and the rear hub is the current issue, it has a fully floating shaft rear axle and when I bought it there where only 5 bolts in it as the sixth had a broken stud in it, got that out with an easy out and put the correct bolt in. After running around it started leaking oil and when I pulled the bolts, 5 of the 6 where snapped! I got two out by drilling and using the easy out, then the drill bit snapped and now I think the hub is stuffed.
    After looking at the manual and seeing what I had, I have a spacer half inch wide between the hub and driving member, so the right bolts are actually half an inch too short!!
    Does any one know if this is a standard S1 rear axle and the spacer is something to use later axles shafts? Once we solve this mystery, does anyone have a rear hub assembly sitting around as I've stuffed mine!!
    I've attached a couple of pic's....
    Jason
    Narrogin WA
    I think the spacer indicates that the axle is from a S2, the S1 half-shaft being shorter; the short bolts explains why they snapped.
    Why do you think that the hub is U/S? You should be able to turn the broken stud with the drill bit in it, with a sharp centre punch and hammer. Hold the hub in a vice and strike anti-clockwise around the periphery of the stud; this should work seeing how oily it has been,
    Cheers Charlie
    Series 1s did not have fully floating shaft rear axles.
    To aid changing axles more easily some people put in fully floating shaft rear axles from later series vehicles. This allows the use of series axles which are longer than series 1 axles - hence the spacer to move the hub out a bit to engage the series 2 axles.
    As Charlie has said - just fix what you have and put in longer bolts - there are plenty of Series 1s running around with the arrangement you have - it works well and is easier to change axles if the need crops up.
    australia
    Quote Originally Posted by Jcrowe69 View Post
    Hi All,
    Jason
    hi standard 1957 si had fully flooating axles jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Dec 2015
    Thanks for your replies guys, I'm planning to keep the set-up but have mangled the hub, I have three clear good holes, two which the drill wandered to the side drilling the stud so the easyout won't move whats left and the last hole the drill bit has busted in the remnants of the stud, I like your idea with the centre punch Charlie but its just too deep and narrow.
    I'm guessing you'd have one of these hub assemblies lying around Jim...
    Jason
    Cessnock NSW
    Jim is correct I had a 88" S1 it had fully floating rear axle, genuine S1 axles as well, cheers Dennis
    Most Series 1 had a semifloating rear axle, but fully floating was standard I believe on 107wagons and 109s in the last year of production, and optional on all others.
    Because the S1 axle housing is shorter than the Series 2/2a/3 axle housing, the fully floating axles have half shafts about an inch shorter than the later ones. Because they were only used on a tiny proportion of vehicles, they are almost unobtainable.
    A common solution is to use the later half shaft, and fit a spacer made by turning the centre out of an axle flange, and this appears to be what you have. And as you have found, that really means you need longer bolts, which being BSF, are not that easy to find.
    If you have drive flange bolts coming loose (not just on this modified setup) make sure that the bearings do not have excess play, as this will very rapidly loosen the bolts.
    australia
    Jason
    yes i will put them on the tralior for cooma jim
    Russell Rovers
    Phone 0428732001
    The subject vehicle is an 86 so would have the semi floating rear axles originally.
    I have two complete 57 88s and a 57 rear axle from another 88 and all are semi floats so all 57s didn't have fully floating but as John mentioned, in the last year of manufacture the long wheel bases transitioned to fully floating.
    Yes, and it also needs to be remembered that at this remove it is almost impossible to be certain that what you see today is what was on the vehicle when it was sold new. Any first buyer for a Series 1 is today at least in their mid seventies , assuming they had a licence at the time, and bearing in mind that few new vehicle buyers in the fifties were that young, I expect most would now be in their eighties or older.
