Coolant level loss could be something as simple as .. at what level are you taking this coolant level loss from?
That is, do you fill the coolant reservoir to the seam .. or do you fill it to the filler neck?
300 Tdi D1 here, but basically the same coolant system: when I do a coolant bleed, I use the coke bottle method, and doing that obviously has the coolant level after a bleed filled to the brim.
When filled to the brim, there's always coolant loss for a short while(weeks or month or so), and it settles itself down to the level that is the seam weld on the reservoir.
It just does this of it's own accord, and once at this level point, it then loses no more.
If you fill to the seam of the reservoir and you notice loss of coolant from that point .. then you'd be well advised to delve further to find a cause.
From my experience with my 300 Tdi, I'd say 50ml is too small an amount to estimate as a loss.
				Arthur.
'03 D2 Td5 Auto
'03 D2a Td5 Auto
