Results 1 to 10 of 13
Thread: Cold Oil, Oil Change
    Dec 2016
    Buderim Qld
    Is it always necessary to change oil that is hot? If I change the oil in my 300tdi gearbox why can't I change it when it is cold? Afterall, it is a thin ATF oil and you would think that most of it would drain out.
    Avoca Beach
    I think the main idea is that any debris in the oil will be mixed in again by the churning about of the engine, gears or whatever and not maybe rest in the bottom of the sump/gearbox.
    I usually drive my car around the block so the oil is warm not hot , which I think is enough to suspend the debris.
    Regards Philip A
    St Helena,Melbourne
    4.28 MB
    No, it just flows better when its warm (not hot) so it comes out quicker. I usually do it after cooling down for a few hours after a run so as not to remove any skin from my body.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    cairns
    I don't think there is much advantage, when it's cold most of the oil has all drained to the sump anyway.
    What I do do is open the filler cap before I drain the sump, this increases the flow out and introduces a flushing type effect.
    I guess the ambient temp might come into play if it was really cold.
    Paul.
    Paul.
    77 series3 (sold)
    95 300Tdi Ute (sold)
    2003 XTREME Td5
    I thought I was wrong once, but I was mistaken.
    NSW far north coast
    Regards Philip A
    This is my theory too.
    Apr 2011
    Dungowan
    Quote Originally Posted by rick130 View Post
    And mine...only drain cold if unavoidable.
    '93 D1 V8 auto
    '93 D1 200Tdi 2-door, ARB's, MD transfer, sill tanks, winch, 2"lift.......
    '95 D1 V8 auto......gone
    '86 V8 RRC.....gone
    Regarding gearboxes/transfer cases, a wise person once told me to remove the filler plug before you drain the oil.
    When things don't work out as they should, its not easy to refill back through the drain hole.
    mike
    Dec 2016
    Buderim Qld
    Quote Originally Posted by llandro View Post
    mike
    What a good idea!
    Brisbane,some of the time.
    mike
    I was told that as well,
    And the wise guy also added,always check the level at the same time,before draining any oil,it will give you an idea if anything is going on.
    Avoca Beach
    An alternative to that would maybe just look under where you park your car every few days. LOL
    Although a level check will tell whether a leak is from gearbox or rear main seal.
    Regards Philip A
