I did a bit of this a couple of years ago in my MY10 110. I think a lot of the actual kit I used is now no longer available, but perhaps some bits of info I found might help.
Someone on here mentioned as to how they'd bought a mech-less Fusion unit for a really good price. And, it literally fitted plug-and-play into their Deefer.
This got me thinking - I wasn't ready to let go CDs, but I liked the USB, bluetooth & hands-free capability they described the Fusion unit had. Also, my research showed that Fusion was NOT top-line but reasonable quality cheapish stuff, and not too blingish. And, I found that they had pretty much the same unit WITH a single CD player. We had a starting point.
Bought it, and yep pretty much plugged straight in. I have the phone hands-free mike just above the front door, with the cable running down the A-pillar, and back to the head unit. Bluetooth hooks up to my phone really well, and the CD and USBs both work very well.
I then found they did a range of speakers. I went for their "best" 5.25 in. versions: "one piece" two-way for the back and separate woofer/tweeter for the front (as per Defender standard). These fitted pretty easily with some careful Dremeling - the trickiest one was the front passenger side, where it went close to an air duct. But not too much of a challenge. All in, all good. I kept the standard speaker wires - probably would improve a bit with better quality cabling but TBH I couldn't be bothered, and figured it wasn't going to give an improve worth what I saw as quite a bit of effort...
Then, I decided I needed a bit more bass. I went with a Vibe Audio CVEN V-series "flat box" active unit. I have this mounted in the load area, on the "steps" - I have other stuff on the back of the cubby box. And, I have it mounted on "strong" velcro, with a quick release plug, in case I need to move it to carry other stuff. This has worked well - while I admit I do not regularly drive over extended corrugations, the unit has not moved in an unwanted way at all. I ran power cables across from the battery, via the B-pillar and then up/over/down the rear door. The audio feed cable and auto on/off from the head unit run via the A-pillar and then again along the top of the doors back to the load area.
This all gives pretty good sound, way up on standard. Hey, it's a Deafener, it's noisy, it's not a great acoustic box, but then like I said I didn't go for top-line kit - didn't want to, and didn't see the point in this car. Most of what I listen to is loud, and this rig sounds good (to me!) loud while driving. Definitely drowns out road noise
Now, the Fusion kit is, I think, no longer available. But, I guess my points are:
- a modern head unit will probably plug straight into your existing wiring;
- 5.25 in. speakers go in with relatively little effort, if you don't mind Dremeling;
- it rounds out nicely with a good sub-woofer, again with relatively little effort.
Hope that helps...
