Results 1 to 10 of 16
Thread: 1995 Defender 110 REAR Disc Rotor's Diameter - is it 290mm or 298mm?
    Jun 2013
    Warner Area - SEQ
    Gents,
    Chasing new Rear Disc Rotors for my 110Defender and having troubles determining which ones to get. There seems to be confusion as some sites say 298mm diameter and others say 290mm. Can anyone verify what diameter are the Rotors?
    Some sites indicate that the Defender 90 has a rotor diameter of 290mm and the 110/130's have a diameter of 298mm..... What's the go??
    rob
    Feb 2005
    I’ve never checked the diameter.......but than again I have only ever brought local.
    Jun 2013
    Warner Area - SEQ
    Yeah, I'm trying to buy local, that's the problem.... the common size coming up is 290mm in diameter but according to Roverparts website, etc the 110/130 have a larger diameter rotor at 298mm (FTC3846). The one for the Defender 90's come up as " LR017953 FTC1381 (min. thickness 11.7mm)"
    9mm difference which I assume is important.....?
    Feb 2005
    Given you have a 110 I’d go on what the web site says.
    4mm on the radius......
    It would also mean either the diffs would be different between the 90 and 110 and or the plate between the diff and caliper would be different.......I cannot quite picture of the caliper bolts direct to the diff or if there is an adaptor plate.
    Jun 2013
    Warner Area - SEQ
    Yeah, I'm going with the 298mm rotor but I don't have an old one in the shed that I can measure up to confirm.... Problem being is that motor Brake suppliers mainly have the 290mm ones listed and don't have the 298mm ones listed which is a bit strange....
    I also checked the offsets and the 2 Rotors have different offsets. The One for the 298mm rotor is 70mm (one for the 110) and 61.5mm for the 290mm rotor
    The thickness between the 2 is also different.....
    Feb 2005
    Quote Originally Posted by Robmacca View Post
    Surely someone will have a rotor sitting on the floor they can measure.
    Jun 2013
    Warner Area - SEQ
    I'm hoping so, but the evidence is pointing more towards the 298mm diameter as there is also differences in the Rotor disc offset and thicknesses between the 2
    Ipswich QLD.
    I have one here from an 02 130, 298 diameter, 59mm overall width from joint face to outside of rotor, 15mm thick. I got mine from Baileys Brake and Clutch, Ipswich.
    Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Jun 2013
    Warner Area - SEQ
    Quote Originally Posted by Killer View Post
    Mick.
    Thanks for that.... interesting that u measured 59mm thickness
    From the info I've found, mine should be 70mm BUT they do make a 59mm x 298mm diameter disc.... I can't believe the various parts u get in basically the same vehicle..... here's a list I've found so far off the following website: Empoweredautoparts
    Landrover Defender 110 130 *298mm Disc* 1993-2007 REAR DISC BRAKE ROTORS RDA7019
    COMPATIBLE MODELS:
    LANDROVER 90, 110 SERIES 1997-1999 REAR
    LANDROVER DEFENDER 110, 130, *check diameter* 1993-2007 REAR
    LANDROVER DEFENDER 110, 130 2.4TD 2007-2012 REAR
    PRODUCT SPECIFICATIONS:
    Solid Type
    Diameter 298mm
    Original Height 59mm
    Original Thickness 14mm
    Min Thickness ie. Replacement 13mm
    Centre Hole 101.6mm
    5 Bolt holes
    Rear Fitment
    Landrover Defender 110 130 2.5 Hardtop 1994-1998 REAR DISC BRAKE ROTORS RDA87
    COMPATIBLE MODELS:
    LANDROVER 90, 110 SERIES, 90 SERIES V8, including country 1984-1994 FRONT
    LANDROVER DEFENDER 110, 130 & 2.5 HARDTOP *solid rotor* 1990-1993 FRONT
    LANDROVER DEFENDER 110, 130 & 2.5 HARDTOP 1994-1998 REAR
    LANDROVER DISCOVERY 2.0L, 2.5TD (solid disc) Including ABS 1989-1999 FRONT
    LANDROVER RANGE ROVER 2.5TD, 3.5L (solid rotor) 1970-1990 FRONT
    Solid Type
    Diameter 298mm
    Original Height 70mm
    Centre Hole 101mm
    5 Bolt holes
    REAR Fitment
    Landrover 90, 110 Series 1997-1999 REAR DISC BRAKE ROTORS with WARRANTY RDA7019
    COMPATIBLE MODELS:
    Solid Type
    Diameter 298mm
    Centre Hole 101.6mm
    5 Bolt holes
    Rear Fitment
    Not sure why the differences as I though ALL Defender models up to the start of the TD5 had the same Salisbury Rear Diff. Unless the SWB 90 model had the Rover Diff in the rear ??
    Would like to hear from the experienced Brains Trust as to "why & Where" the differences ??
    May 2006
    Woolgoolga
    Defender 90, RRC, Disco1 rear rotors are the same. Defender 110 and 130 rear rotors are the same!
    I recall this as i once bought the defender 90 ones for my salisbury and they didn't fit. Wrong offset
