Results 1 to 2 of 2
Thread: LT230 collapsible spacer
    Jul 2008
    Banana Qld
    Hi all,
    I have got my TC apart on the bench as it was getting a bit noisy.
    Because I'm not real smart, I didn't order a rebuild kit from Ashcroft's that would have been cheaper and complete.
    I don't have a new collapsible spacer for the intermediate gear.
    I have measured the one that came out thinking I could machine up a spacer of that length, but it is not square, it ranges from 58.83 - 59.92 long.
    Makes me wonder how good a preload unit this was.
    Would I be better to order a new colapsible spacer or a fixed length one, but of what length?
    Also is a HD cross pin needed for normal use, or do they also reduce wear on the thrust washers or have other advantages?
    Oct 2012
    FNQ
    Make a new spacer at 59.92 set up as pic and measure float trim to size with a few thou for preload
    AM
