Results 1 to 10 of 17
Thread: Airflow snorkel install
    Feb 2018
    Hi all have just purchased a disco 4 airflow snorkel.. now my question is about the pillar mount bracket in the diagram and instructions it doesn’t say anything about the plastic cover on the pillar. The rest is straight forward.. has anyone had anything to do with the airflow snorkel install and if so could u please let me know about it please ..!!
    Feb 2018
    Also forgot to say it was the 2.7 tdv6.
    Thank u
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Davetheaviator View Post
    There is a post here with some detailed info on the install, i fitted one to my D3 and it was less than straight forward.
    I removed the A-pillar trim and drilled a hole and used the supplied plastic plug, then drilled thru the trim. I had trouble with the 2nd hole so just went thru the trim.
    There is some cutting of the inner guard supports behind the intake grill and in behind the airbox.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2018
    Ok thank you so I do have to cut a slot through the plastic pillar trim all good just nothing mentioned about that .. is the bracket long enough to grab the snorkel once it is mounted to pillar..?? That’s what I thought but just wanted to double check... thanks for your help..
    also how did u find the snorkel..?? Looks of good quality..
    Oct 2006
    Australia
    Smile
    If it is an LR offering it is not a snorkel, just a raised air intake.
    I can supply fitting instructions (PM me) as I fitted one to a D3 shortly after I got the car and only had a problem with the rivnuts on the mudguard (I do not have a rivnut gun and devised a workaround ).
    St Helena,Melbourne
    4.28 MB
    Quality is good, no just drill a small hole in the trim and screw the bracket to it. Bracket will need some bending to line up.
    1974 VW Kombi bus
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by LeighW View Post
    Airflow brand not the lr rai.
    1974 VW Kombi bus
    Feb 2018
    Yeah it the air flow brand so I do just drill hole in plastic trim and put the plugs into the trim and screw bracket onto that...
    Thank you for all your help ,
    St Helena,Melbourne
    4.28 MB
    No plugs go into A pillar so screw goes thru the trim and into the plugs.
    1974 VW Kombi bus
    Feb 2018
    Ok got u.. thanks heaps
