Results 1 to 10 of 13
Thread: Australias first Super Capacitor installation
    Aug 2010
    Sunbury, VIC
    Listening to the radio this morning, a Melbourne company has just installed in a home a system that uses super caps instead of batteries to store power. Cost per KWh is almost the same as Lithium, but set to fall as the components are much cheaper - carbon the form of graphine and aluminium. Charging cycles are around 1,000,000 and design life is around 45 years, with no toxic chemicals or exposion risk due to mischarging etc. The can accept pretty much an unlimited charge current and can also discharge quickly if needed and can be taken to dead flat with no effect of the lifespan.
    They are now bringing in 200 more units, that are all presold.
    Quite impressed - Lithium may go the way of the dodo before it even gets into top gear - Elon Musk is reported to have said they are now looking at this tech for their cars.
    Will be interesting to see where this goes in the next few years. 👍
    DiscoMick Guest
    Do you have any more information? Sounds interesting.
    Jan 2017
    Geraldton WA
    I wonder of you could use these to store lightning
    4.6m Quintrex boat
    Mar 2007
    Warwick Qld
    I often wondered about using caps as batteries when I was playing around with computers - you could get a pretty good zap off the big ones, even a day or so after powering down the system.
    Wonder if you could claim carbon credits for the carbon you put in them?
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Dec 2008
    Tewantin, Qld
    Quote Originally Posted by Homestar View Post
    I'd reckon that they would end up with a mix of super caps and batteries. Supercaps for the regen braking and the batteries for longer haul. Capacitors by their very nature will self discharge faster than batteries and at a guess the supercaps would have to be heavier than Lithium per KwH.
    Cheers Glen
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by DiscoMick View Post
    Was trying to find the article earlier but with limited success. Will have another look when I get a moment.
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Dorian View Post
    Cheers Glen
    Weight is about the same apparently - not sure on self discharge levels, but small super caps in electronics will hold their charge for months.
    A combination of the 2 would make sense.
    A few years ago when electric bikes began racing at the FX Superbike series, I asked one of the riders about regenerative braking.
    He said that while racing bikes brake hard, it is normally only for brief periods and that it is hard to feed power into batteries that quickly.
    He suggested that capacitors might be the answer. So a combination of batteries and capacitors seems to make sense.
    Aug 2010
    Sunbury, VIC
    The interview I heard it on was on ABC - the podcast of the whole morning is here - Mornings - Mornings - ABC Radio - it’s about half way through.
    DiscoMick Guest
    Thanks for your trouble. I have also done some other reading. Interesting stuff.
