Results 1 to 10 of 11
Thread: Catch Can on 4.6 GEMS V8
    Feb 2013
    Gosford, NSW, Australia
    Question Catch Can on 4.6 GEMS V8
    Hi
    I am thinking of installing a Mishimoto style 3 port Catch Can on my 4.6 GEMS V8 engine to limit the amount of oil going into the intake
    Currently;
    there is a hose from the left rocker cover to the intake near the butterfly valve
    and on the right rocker cover with the tree like "oil separator" in it which goes to the plenum at the rear right
    I am thinking of taking both of the rocker cover "intake" hoses to the Catch Can but i am not sure about which inlet to use, the one at the butterlfy or the one on the plenum
    Hoping the aulro brains trust can help
    Steve
    Crafers West South Australia
    The right hand (manifold vacuum) one operates mainly at low throttle, the left hand one mainly at high throttle. At low throttle clean air is drawn into the engine from the throttle body (inlet) side by the vacuum side. So by choice the oil separator would be best on the manifold vacuum side as this always delivers fumes.
    Feb 2013
    Thanks mate, perhaps it would be best to add a T-Piece and join both inlets to the catch can inlet
    Quote Originally Posted by TheTree View Post
    Allowing fresh air into the engine helps keep it cleaner, clears condensation, reduces varnish build up. I wouldn't consider this mod to be particularly worthwhile. Perhaps consider two catch cans if you must have them. Are your rings excessively worn?
    Feb 2013
    My rings are fine but my valve stem oil seals were shot ... guy installed commodore ones instead of k-line and they were crap. Just replaced them with k-line seals
    Maybe i should wait and see how oily things get now with the new seals and if I do go the catch can route, only put it on the right side in place of the oil separator "tree"
    Thanks for your input
    Steve
    A slight diversion from topic - thanks for that information I did not previously understand the subtle differences related to the passenger side. I though that as the intake was before the throttle body that it was simply the point for taking filtered air into the crankcase via the passenger head then sucked into the engine by engine vacuum on the drivers side into the inlet manifold.
    Now the topic diversion - at least for a while I am still going to have my old venturi gas system (from my old carb 3.5) on the car so when on gas there will be a LPG/Air mixture in the inlet system before the throttle body. So I guess this LPG/air mixture can get sucked into the crankcase (boom ) and then sucked into the inlet manifold via the drivers side rocker. An issue?
    If yes I was thinking of not having the passenger side inlet in the rocker not connected to the throttle body just before throttle but have its own small filter to filter the air or plumb it to the air filter before the gas mixer.
    Thoughts?
    After I have this engine up and running on dual fuel with its new petrol ECU I will then look at converting the old LPG system to a more modern injection system.
    Feb 2013
    Thoughts?
    Hi mate,
    Yes the one on the right operates mainly at idle because the inlet manifold has a high vacuum at idle, however at higher revs the manifold vacuum is low so the right one would not suck very much; however the left one would suck due to the venturi effect of the air being drawn past it.
    I doubt any significant amount LPG/Air mixture would get sucked into the crankcase, if you are worried about that a PCV type non return valve in the left tube would stop any flow from the throttle body back into the crankcase.
    Not sure about the effect of feeding only fresh air into the throttle body, this kinda defeats the purpose of the PCV system which is to get the crankcase fumes/blowby and put it back into the combustion process so it is burnt rather than being vented to the atmosphere.
    I have decided to leave the left side alone for now and I am monitoring the oil build up on the right to see whether it warrants fitting a catch can.
    Steve
    Thoughts?
    Having the fresh air connection upstream of the LPG mixer is standard practice, many mixers have a connection point for this purpose. The trouble with this is that the original fume vent prevents oily goo from entering the IAC valve as the connection is usually on the opposite side of the throttle body. Running the fumes through the LPG mixer means that the IAC may gunk up after a lot of high load driving. So do it whatever way you need it for now, and hook it back up to its original connection when you get LPG injection. Allowing the sump to fill with combustible LPG/air mixture is unwise. I've seen a couple of engines that have ignited this mixture, the results were "interesting".
    Thanks to you both - I will just leave it open to the atmosphere with a cheap in line fuel on the end of a bit of pipe so that any air that is sucked into the engine is filtered. Then change it back to original when I inject the LPG. The only reason I have the old LPG on is that the engine can run on it while I sort the electronics out for the petrol side out of things.
    I have heard what you both have said about the passenger side rocker cover inlet allowing air into the crankcase at low revs but sucking it out at higher revs but I have to say I am not convinced. The Oil Separator Breather Pipe Insert only goes on the drivers side and catches the misty oil so it flows back into the engine.
    If the passenger side also sucked out the oily mist at higher revs then surely a Oil Separator Breather Pipe Insert should also be fitted to the passenger side but I believe it is not.
    Feb 2013
    Hi Mate
    I am not sure about the passenger side allowing fresh air in, it can only get air from the rocker cover and crankcase on my MY96 GEMS.
    I think the reason there is no separator on the passenger side is that the vacuum and suction is never going to be anywhere as high as the drivers side which can be between 14 in. and 22 in. Hg.
    Steve
