Results 1 to 9 of 9
Thread: Stage 1 Isuzu supplement
    Sep 2017
    NSW
    Would anyone know where I could purchase a stage 1 Isuzu workshop manual supplement. As I am constantly having to work on her to keep her on the road life's getting hard without the supplement.
    Also, is the nut at the bottom of the bellhousing behind th sump plug a drain for the gearbox or a drain for the oil leaking out from the main engine seal.
    The hole in normal use is left open so any fluids from either the engine, gearbox or from elsewhere in the bell housing can escape - drain out. The screw in plug is normally stored in a threaded receptacle in the bell housing a couple of inches to the left of the hole.
    When fording a creek or in other scenarios where water could get into the bell housing you move the plug from its receptacle and screw it into the hole sealing the bell housing. When no longer needed it should be removed and screwed back into the storage position.
    Here is a pic of mine - you can see the threaded drain hole and the plug in its storage position.
    So leave it here most of the time until needed.
    Sep 2017
    NSW
    Thankyou
    hankyou for the reply, Is that picture of the Isuzu with the LT95? As it looks differnent to mine?
    T
    Brisbane, Queensland
    Is this supplement you mean?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Quote Originally Posted by Series 3 stage 1 View Post
    T
    That is a V8 but you should have a similar arrangement.
    Sep 2017
    NSW
    Quote Originally Posted by rar110 View Post
    I am not sure, if it has the Isuzu 4BD1 in it then yes please!
    I feel though this is for a series 3 3.9 D Land Rover powered diesel not the Stage 1.
    Last edited by Series 3 stage 1; 11th March 2018 at 09:50 PM. Reason: Additional information
    Hay Point
    - Same beast if your stage 1 is a 3.9 isuzu. The series 3 with a V8 or Isuzu was termed a "stage 1"
    Cheers......Brian
    1985 110 V8 County
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    the 4bd1 dvd in the shop has the australian user manual supplement as well as lots of other goodies...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2022
    DVD
    Quote Originally Posted by incisor View Post
    Thank you for the heads up on the DVD. I have just bought it from the shop and can’t wait to get it. I bought a 1983 Stage 1 with the 3.9 motor and there is so much to learn.
    I want to try and add power steering and improve the brakes. If i could do that i would keep the car forever, which won’t be very long as i am getting older, ha ha.
