Results 1 to 10 of 18
Thread: Urgent Advice - Car Crabbing
    South Yundreup,WA.
    Hey guys,
    After some urgent advice. This morning the Defender TD5 started behaving weirdly and dangerously.
    I initially thought maybe steering issues, but seems to be something else.
    Under load everything fine, but when taking off load or foot off accelerator it seems to lurch and pull right, almost feels like the rear end is being pushed sideways.
    A little bit the same when accelerating as well.
    I have recently fitted an ATB to the front and new ball joints but has been fine for well over 1500kms with no issues.
    I have noticed what I believe to be the transfer case bearing getting a little noisy.
    Is it likely this would be a transfer case / centre diff issue or rear diff issue / axle?
    Have also rocked the wheels to check for any play in the wheel bearings and none. Steering itself feels tight.
    It is a really disconcerting feeling and dangerous so will be getting parked up when I get home tonight.
    It almost feels like you lose steering for a second or maybe losing drive / getting drive.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    cairns
    Sounds a bit like the centre diff is locked and you have transmission wind up.
    Paul.
    77 series3 (sold)
    95 300Tdi Ute (sold)
    2003 XTREME Td5
    I thought I was wrong once, but I was mistaken.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Have you checked your rear trailing arm bushes? If they are flogged the rear diff will torque on acceleration and un-torque on deceleration which feels like rear steer. It's too early on a Monday to mentally work out which way it will steer the truck but to the right is my vague recollection.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Aug 2015
    Moe
    A very long time ago I had the misfortune to own an Alfa 1750 Berlina money pit.
    At one stage it did the same thing and it was some of the rear suspension bushes. With the rear jacked up by the body I could push and pull the rear wheels back and forth and with LOTS of pushing the whole rear axle could be moved sideways. The hand induced movement was only a few mm or so. A new set of expensive and hard to fit bushes and all was well again.
    And if you think a Land Rover can be a money pit try an Alfa on for size.
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    Apr 2016
    Country Vic.
    Yeah, first things I'd look at are for play in the trailing arm bushes.
    Chassis end are notorious for wearing. check nuts for tightness.
    Also check rear balljoint for wear/play too. But if it is worn, they usually clunk/thunk before they get badly worn.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    South Yundreup,WA.
    Quote Originally Posted by harro View Post
    I dont think that is the problem, have had diff wind up before and quite different. This almost feels like you lose drive & steering. A bit disconcerting. Started suddenly this morning.
    Craig
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    South Yundreup,WA.
    Quote Originally Posted by AK83 View Post
    I will check them, have a spare set if required, but onset was quite sudden. I would have expected gradual issues.
    I do know the trans case bearing has started to make noise.
    Only thing different is I changed the rear diff oil day before yesterday.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    South Yundreup,WA.
    I have an adjustable a frame ball joint, so should not be that.
    If it was bushes would it not do it all the time? This seems more to be when unloaded / taking foot off accelerator.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    South Yundreup,WA.
    Quote Originally Posted by MLD View Post
    Yeah maybe and will check as it does seem to push more to the right and feel like rear steering.
    Pretty sure I have a new set of bushes in the shed, so will swap them out.
    Just weird that it came on suddenly.
    Will have to wait until Friday to repair though. Will park it up tonight as I consider it to dangerous to drive, pushed me over the centre line a couple of times on downhill corners. Slow trip home tonight at no more than 80kms per hour I think.
    Could also explain the clunk that does not seem to be the A Frame Ball Joint.
    Craig
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Kingston, Tassie, OZ.
    I would also be looking at the rear end steering through trailing arm bushes or upper a frame brackets/bushes.
    Exacerbated by the true track no doubt due to a sudden weight transfer when the directional change forces the body sway...
    Jc
