Results 1 to 10 of 32
Thread: Saggy hood lining
    Bracken Ridge, Brisbane
    Saggy hood lining
    Any suggestions where to get a saggy hood lining fixed in Brisbane at a decent price ?
    Any motor trimmer should be able to do it.
    Forget trying to glue it back up - been there done that. The foam backing on the cloth breaks down so you would be wasting your time to attempt a repair.
    I pulled the roof out and glued it up but it didn't last. I took it to a motor trimmer and he pulled it all out again and re-did it with new cloth for $200 - and that included refitting it.
    The far superior appearance of a job properly done will soon negate any bad thoughts about the cost.
    The P38A is starting to sag in a couple of spots so will need doing soon(ish).
    Ron
    Let me know if you find a place.
    I think Vlad had his done before purchase ....
    Earth to Vlad ..... come in Vlad
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    Yep will do :wink:
    DionM Guest
    If you pull it out / put it in yourself, try a mobile guy. Tell him it will be waiting on saw horses for him, he just has to cover 'em. Makes it a lot cheaper.
    Somewhere else, QLD
    hood lining
    Try finding a pre 1993 Disco hoodlining - it's of a different construction and never falls down - You can scrub it and it will look like new. It needs a bit of persuasion to get it in, but looks 100%. If it gets creased, wet it with a hose, and let dry out over a few days.
    Langy
    Newcastle
    while it is down, stick a heap of sunroofs in, helps stop future sagging, and increases the trucks value,
    I think my budget might stop me at the hood lining,
    Nov 2005
    Maudsland, QLD
    My rangie needs new lining so keen to see a cost if you find someone :wink:
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Only had 1 price so far $300
