Results 1 to 6 of 6
Thread: Fairey overdrive breather pipe
    Dec 2010
    Kiewa Valley, VIC
    Can anyone recommend a fitting to run a breather line on the fairey? I have no idea how to source a suitable threaded hose connector. I have heaps of 5mm pipe, just unsure how to connect it to the top plate. There must be a suitable threaded joiner somewhere?????!!!!
    I see others run a connected breather to the transfer box also. Is this necessary?
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Sandgate, Brisbane
    For stuff like this I usually takes the bits I have to Enzed & they help me find the bits.
    I drilled out the pin size breather on the top plate and tapped the plate and screwed in a barbed fitting. This allowed me to keep the baffle on the underside of the top plate. Run a long breather or put an in-line filter in it to stop oil getting pushed out, otherwise it will empty itself.
    Same, I drilled it out and tapped to BSP, used a few brass pipe fittings to offset it to clear the centre tray, and just raised it about three inches with an axle breather on top. No longer chucks the oil out.
    Dec 2009
    Queensland (though occasionally elsewhere)
    Quote Originally Posted by Michael2 View Post
    Ditto. Worked a treat.
    Nov 2007
    Townsville Nth Qld
    As above i found that any oil that was thrown up tube ran back into overdrive unit.
