Results 1 to 10 of 11
Thread: Oil Pressure Dropouts
    Melbourne, Vic
    Okay, took the beast up to toolangi on the weekend as a bit of a shakedown test. Had a few minor issues, but nothing to stop me getting home.
    Anyway, I found that on the inclines of say, 20-25% +, occasionally, the oil pressure would disappear for a short couple of seconds. It'd typically happen after a pause/restart and then would go away when the revs picked up.
    It's been a while since I changed the oil (a month or so) so the it may be a touch below full.
    I have a remote oil cooler & filter installed, and my theory is that, due to fact the extra oil required to fill the oil cooler/filter there's less oil in the sump. This in turn would 'slosh' to the back of the sump - far enough away (and sufficiently low level) that'd mean the pickup isn't fully submerged - so the pump would likely struggle to suck up enough oil.
    I added a bit (300-400mL) when out, and it seemed to almost go away (happened a couple of times more over the course of the rest of the day).
    Is my theory about right? Would the car be more sensitive to oil levels offroad - especially given the remote oil cooler/filter?
    N
    Current: ‘16 Disco Sport (7seater) aka « Family Bus 2 »
    Sadly Gone: '77 RRC 2 Door aka "Beast"
    Gone: '92 RRC Vogue SE aka "The Family Bus"
    Long Gone: '99 Td5 Defender aka "The TANK!"
    Melrose SA
    Quote Originally Posted by drover81 View Post
    N
    What is it?
    Melbourne, Vic
    Quote Originally Posted by djam1 View Post
    What is it?
    Ah yeah, forgot that part - p76 V8 in a 2door RRC
    Melrose SA
    Oil pressure gauge or light ?
    Melbourne, Vic
    Both
    Crafers West South Australia
    Is it running the P76 sump? These were known for oil surge problems and a modified oil pickup was fitted to later models. My P76's used to be run with the oil level at the top of the word "MAX" instead of the full line. I did some fairly steep off road driving in these things back in the day.
    Melbourne, Vic
    Umm - pass (not sure). I have no idea how to confirm what sump it is. Is there any visual cues?
    Avoca Beach
    I had something like this happen when I had an oil cooler with a thermostat fitted in the lines in a77 RRC.
    I would start at the bottom of an incline then after the oil got warm, I would lose oil pressure as the thermostat opened and the oil filled the empty oil cooler lines and the oil cooler.
    I really don't think you need an oil cooler with modern oils.
    I think the problem is caused by the oil cooler draining back to the sump. Also Check that the oil cooler lines go into the TOP of the oil cooler not the bottom.
    Regards Philip A
    Sump plug. P76 has a 3/4" hex head and 1/2" UNF threaded plug on an angle, Land Rover is a fair bit bigger than 1", pointing horizontally.
    Melbourne, Vic
    To ask another way - I use the same socket (34mm from memory) that I used on a 1991 RRC - to remove the sump plug. Does that mean it's a rover sump?
