Results 1 to 9 of 9
Thread: ACE high pressure line repair
    Jan 2011
    Gippsland
    I have a ruptured ACE high pressure line. I’m stranded in Gippsland atm and the local heavy vehicle workshop is thinking to cut out the damaged section (about 25mm) and use hydraulic fittings to repair the line however they’ve not found suitable connectors yet - have any forum members had similar experience and could offer some advice ....?
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Jan 2017
    Geraldton WA
    Can they use the original fittings and replace the section of hose or can they just use new fittings and make up a new hose?
    4.6m Quintrex boat
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by onebob View Post
    I don't have one here with ace at the moment but I have, in the past used 15c brass compression plumbing fittings to get someone out of a bind with trans cooler lines , so if the ace line is the same diameter they would work , you'll need to use the copper olives though, not the nylon ones they usually come with.
    Quote Originally Posted by trout1105 View Post
    I’m guessing pipe not hose.
    Jan 2011
    Gippsland
    Thanks for the replies - enzed and pirtek were unable to help so it’s a new hose / pipe i guess ...
    LROCV member #131
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    I nearly hit a pole and rolled my disco going around a bend when a repair let go. The rams twisted and you lose control. Very indie soiling experience. Be careful with removing any pipe from the age valve block once disturbed they can leak.
    Apr 2015
    Hervey Bay
    I blew one of my flex lines in the rear on my ACE in my D2 while coming down the Karanda range here in Cairns.
    I took the lines to Enzed who made up some replacements by welding some JIC fittings to the end of the hard lines then made up some new flex lines. Worked a treat never had a problem again.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Sep 2010
    The Hills.
    152.79 MB
    Well do I remember the skid marks.... At least, the ones on the road, that is.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by johntins View Post
    notice the grass on the nature strip has grown back, skids? what skids ?
