wheres that link,,,
does this help?
land rover spring specifications
 ChatterBox
						Supporter
						ChatterBox
						SupporterHi chaps, I'm wondering which (if any)
Springs from other rovers are compatible/same as the Springs on a defender, if there are any, what's swappable?
wheres that link,,,
does this help?
90s can cross with D1/RRC and D2 rears.
110 fronts can use all above fronts
110 and 130 have larger rear coils so exclusive to them.
D2 fronts have a locating tang so are a bit independent.
Is it right that standard 130 fronts are also 110 HD fronts?
 ChatterBox
						Supporter
						ChatterBox
						SupporterSo if I'm reading correctly, all defender rear Springs are different to everything else?
the 110hd fronts are perfect for bulbar + winch
2015 Defender 110
