Hi guys,
Can the factory roof bars be removed from outside - or does the headliner have to come out??
Cheers, Charles
1999 Disco TD5 ("Bluey")
1996 Disco 300 TDi ("Slo-Mo")
Definitely a headliner removed job. I removed mine to reseal (Sikaflex) them as part of chasing my leaking roof issue. As mentioned above required the drilling out of some pop rivets which is a pain as if the drill bit catches and spins it it melts the plastic that it's securing in place.
Thanks guys ...
