Thread: Intermittent Starting
    DiscoUser Guest
    Hi All,
    Having trouble starting my 300TDi Discovery (233000Kms) after about half an hour from last running the engine.
    Fuel supply is ok, and glow plugs are relatively new. Battery is one week old and injector pump is rebuilt at 214,000Kms.Injectors are about 40,000kms run in.
    If I let the timing to the glow plugs run for 3 consecutive periods then the beast will start. I'm thinkng of re wiring the cabling to the glow plugs to see if this improves the situation.
    Other problem I have is that the engine sometimes does not shut off when the ignition is switched off. The stop solenoid is about 1000kms old.
    Has anyone had any of the above problems??
    Any advice would be welcome, thank you.
    Disco user
    South Yundreup,WA.
    Sounds more like an ignition problem or high tension wire problem. Check all the connections are clean and not broken / worn.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Jul 2003
    Hi DiscoUser,
    How long has this been going on (you appear to have been whittling away at the fuel system for a while)?
    I'm sure that it won't be the glow plug system as the engine will still be warm after half an hour and glow plugs really are only for cold starts on cold days.
    It sounds like fuel starvation to begin with and an excess of fuel (engine run on) to finish.
    If it was mine I would be off to a diesel engine specialist (like Berrima Diesel) for a complete check.
    Hope the brains trust here can help.
    Mahn England
    Ex 300Tdi Disco:
    May 2002
    Heathcote (in "The Shire")
    I'd be starting at the wiring associated with the stop solenoid.
    Bushie
    SYDNEY -in the shire.....
    <span style="color:blue">i second that....
    it will stop it from starting and also from switching off......
    you seem to have given us the answer you are looking for.....
    check to make sure the stop solenoid is functioning correctly......</span>
