Results 1 to 6 of 6
Thread: prototype barrier thingy
    Apr 2010
    Gosford, NSW
    Hi, I have been having issues with shopping falling out the back of the RRS when I open the back door... wishing it had a 2 piece door like my old volvo XC90 (or FFRR, D3/D4) . Anyway I thought I would conjure up a manually deployable shopping-falling-out probability reducer. Just clips on to the load loops, and folds away for easy storage (at least it might if I used countersunk screws on the hinge) . At this stage it only uses 50mm high aluminium, because that's all I could find in right angle at the hardware shop, if it seems to be actually helpful I might increase the height and use a better hinge. Anyone else made something similar? I'm sure JLR could make this accessory and sell it for about $3,590.
    Tangambalanga
    Good thinking. You can buy angle that’s about 150x50 that I know of, and I’m sure you could probably get it even bigger if you wanted. You’d need to go to a specifically alloy dealer though. The other 💭 is if all you want to do is extend it a bit, just get some flat plate to rivet/bolt straight to what you already have.
    Nice job
    Dec 2011
    Bundeena
    Quote Originally Posted by Gregz View Post
    They do have solutions, not quite that much though:
    Load space retention rails:
    VPLGS0171 - Loadspace Rails for Range Rover L405 Sport L494 and Discovery Sport | LR Parts
    ....but you need to have these installed to use the above:
    VPLWS0242 - Range Rover Sport L494 Loadspace Rail Rentention Set 5 Seat | LR Parts
    A retention net (Like a blind across the back):
    VPLWS0206 - Range Rover Sport L494 Load Retention Net | LR Parts
    A retention net (to go over your 'load' - this one is for the D4 and will just hook on to your tie down points):
    Luggage Net Elasticated - EOO500010PVJ - Genuine | Rimmer Bros
    Sean
    Apr 2010
    Gosford, NSW
    Quote Originally Posted by SBD4 View Post
    Thanks SBD4 - This one actually looks promising, I have not noticed this item before, not sure why. ... would have to think about how to store it in the car when not in use.
    Edit: I now know why I haven't noticed this before, it is not actually a L494 accessory as far as I can tell, L494 has no holes to hold it in place.
    ...Greg
    Feb 2010
    Stellenbosch, Republic of the Western Cape, RSA
    An easier solution, which I have been doing in all my cars over the years, is to buy a non-slip mat for the boot, and then just place 2 ammo boxes there.
    The non-slip mat I get from the local hardware store and they cut it to size.
    Feb 2010
    This is our A3, you get the idea.
