Results 1 to 3 of 3
Thread: Td5 water pump
    Mar 2018
    Ballarat
    Td5 water pump
    Hi guys, looks like my td5 defender needs a new water pump. Anyone done one recently? Big job? Expensive???!
    DIY is cheap allow a day if your ok on the tools..
    You’ll need a few other bits as you take some stuff off to get to it easily.
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by justgeoff84 View Post
    Intake hose out of the way , serpentine belt off ,4 bolts to move a/c compressor forward, 3 bolts on rotor filter housing, 2 nuts for oil return on sump, remove housing, bottom hose off , 5 bolts to remove water pump housing, remove water pump , clean , clean again, fit genuine pump , reassemble with new oil rotor housing 0 ring and return pipe gasket, more than 4 hours r and r ?.........dcm
