Results 1 to 10 of 34
Thread: rangie operating temps
    May 2003
    where ever I fall asleep ,Queensland
    ok having just done the head gaskets on thumper ,took it for a run last week, just up the road and up the hill to spicers gap,temps went thru the roof (3/4 to 7/8) ,was told that it was probably due to non exsistant thernostat,so have replaced it with a new one ,and retraced the run today and got the same results,thumper is running one thermo fan behind the radiator(always on) and two in front of the radiator,
    any theories,suggestions?
    Piggabeen (Tweed Heads)
    Running temps
    What was the cause of the head gasket failure??is it still there??
    Is the cooling system properly bled and pressure tested.
    How old is your radiator is it the original 86 unit??
    How is the water pump??
    The 2 fans in front usually are for the air con condensor, why does the thermo fan run continuously is it telling you something or is it not wired with a t/stat. Also what diameter is the fan and does its cowling cover the whole radiator??
    Hope this helps.
    Williams West Aust
    Hi Ferno
    Bleeding thermostat problems :roll: :roll: :roll: :roll: :roll:
    You may have air trapped in the system,if your thermostat hasnt got a bleed hole to allow air to pass thru,drill a small hole.If air is blocked at the thermostat the hot water wont open the thermostat.
    Also a trap for new home mechanics,is the thermostat installed the correct "way around" ops: ops: ops: ops: ops: ,should have "to rad" stamped one side,many dont.The spring side needs the hot water flow against it to make it open.
    Best of luck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Avoca Beach
    Have you been up Cunningham's gap on a hot day before with only one electric fan with no probs.
    Under about 60Kmh the fan plays a role as you go slower. One electric fan has about 1/10 the cooling capacity of a viscous.
    Why not borrow a viscous and try it?
    Dirty rad, no viscous would be my picks.
    Regards Philip A
    May 2003
    On The Road
    Ferno, having owned a 3.5 for some time now I can tell you the guage gets to the middle slowly,, but never EVER moves more than a needle width either way, deserts, northern territory highway, city traffic, NOTHING makes it move.
    8)
    Seal on radiator cap going?
    I've got that at the moment, I can just see dribbles of dried coolant around the top of the bottle.
    Simon
    Maryborough QLD
    Sounds like a radiator blockage if the temp goes through the roof.
    I've found that a rad clearout is good practise every 1-2 years or so. I've always had them done every year and found most of my cooling problems are non-existent.
    Did you replace your water pump? I know it costs a bit extra when you are doing any sort of engine work, if your original was a bit suss I would replace it for the sake of eliminating headaches.
    Stupid question, you did put the gasket on the right way? Also did you gradually tourque your heads ot did you just go straight up to 70ft/lbs or whatever they are (can't remember what the torque setting at this point in time).
    Just some ideas of where to start. Thermostat also as well as air trapped in the system as others have mentioned.
    Good luck,
    Trav
    joe Guest
    Somtimes the rad hoses will squash flat if the rubber in them has gotten week.
    Get the temp to go over half after a short run , then pop the hood look in and give the engine some hi revs by hand , you may see that the water pump sucks the pipes together as the thermostat opens up 8O .
    I have had cars in the past that have done this.
    hope it helps. :wink: .
    May 2003
    :roll: ok,from the top,
    DRanged Posted:
    Hope this helps.
    cause of original problem was a lower rad hose blowout,possible caused by dicky thermostat,hose and thermostat replaced
    system bled as best i can do, but i dont have a pressure tester
    have only had the vehicle a month or so ,so cant tell how old the rad is
    the water pump "seems" to be working ok
    not sure why fan is permanently on ,it does have a t/stat wired in but maybe not working or adjusted rite
    and this is where i tend to lean towards the probs ,the fan only covers about half the rad as does the cowling
    next :roll:
    LandyAndy --------------------------------------------------------------------------------
    Hi Ferno
    Also a trap for new home mechanics,is the thermostat installed the correct "way around" ,should have "to rad" stamped one side,many dont.The spring side needs the hot water flow against it to make it open.
    Best of luck
    Andrew
    thermostat is a new one ,it has a bleed hole in it,and i am far from a new home mechanic :roll: i think if i can tackle a head gasket job on a V8 then i should know how to put in a thermo (first job was two years mech app :roll: )besides ya just put it in the same way it came out
    next
    PhilipA--------------------------------------------------------------------------------
    Regards Philip A
    where did you get cunninghams from? and no,i havent been up there before as i have only just purchased this vehicle(may have been a big mistake ops: )any one got a spare viscous and shroud?
    next,
    Pedro_The_Swift
    except for a very hot motor,thermostat opens in a saucepan of water just as it boils,seems strange that it has to boil before it opens,thought it would have opened a little earlier than that
    next,
    abaddonxi
    Simon
    have tried a couple of different caps,no difference :roll:
    next
    aquarangie
    Good luck,
    Trav
    rad seemed clean ,put the hose thru it tonite ,backflushed, and it flowed quite freely,yes, i put the gaskets on rite,it said top on one side ,so i put that side to the top of the motor
    nah,just kidding
    and yes, i did it in three stages
    next
    joe :
    Get the temp to go over half after a short run , then pop the hood look in and give the engine some hi revs by hand , you may see that the water pump sucks the pipes together as the thermostat opens up .
    hope it helps. .
    most hoses are well and truly expanded by the time it gets hot :roll:
    thanks for the info guys ,am leaning towards the fans being the problem,so need to find a viscous coupling and fan blade and shroud, any one got a spare lying around?
    Avoca Beach
    [quote="fernockulated"]:roll: ok,from the top,
    DRanged Posted:
    When you said "Up the hill to Spicers" there is/was a turn off to Spicers just over Cunninghams gap. I believe a part of the old Spicers road with the convict pavement is now closed. Havent driven it for 20+ years
    So you were talking about going up the track to Spicers. IE you were going slowly in low range. Then almost certainly viscous and/or radiator.
    Regards Philip A
