Results 1 to 10 of 15
Thread: Ashcroft Locking Diffs
    59bluebear Guest
    Hi to the forum
    Looking for some feedback on Ashcroft Locking Diffs, I am thinking of having some fitted front and rear to my Disco,
    Does any one have feedback positive or not about the performance and reliability?
    One last question has anyone bothered with the Ashcroft pegging kits to strengthen the diff housing?
    My disco is a td5 auto mainly used for touring and fairly easy off road not extreme completion.
    Thanks in advance.
    Crafers West South Australia
    I organised a fully built up Ashcroft air locker diff centre for a friend's RRC, complete with pegging, and the owner couldn't be happier. The diff pegging is like an insurance policy, rarely needed but handy if you ever have to give it a bit of curry in a difficult spot.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by 59bluebear View Post
    Hi to the forum
    Thanks in advance.
    For the use you mention, I would have thought the ashcroft ATBs would have been quite adequate. I have a pair of similar trutracs on both cars, and could not be happier. Fit and forget!!
    NSW far north coast
    IMO the Ashcroft locker is one of the best designed/engineered lockers for a Rover diff you can get.
    As beeutey said, pegging is insurance, but if you are just running standard sized tyres probably not needed.
    If you were ruining a Maxi Drive low low, 33"+ tyres and a big chip, big IC, etc then yep, definitely worth doing.
    Mar 2015
    Horsham Victoria
    Have you considered jack McNamara 6 gear centers and Ashcroft axles, I run this set up on my td5 auto cheaper than lockers, but tough enough for what you describe.
    59bluebear Guest
    Locking Diffs
    Hi to the forum
    Thanks for the reply's gives me some ideas.
    Jun 2011
    Victoria - Pakenham
    I run the ATB front and rear. With the traction control they are the bees knees. Couldn't be happier.
    Whichever you decide to go with you will not be disappointed with the quality. Remember if you decide to go ATB and pegged then the outside circumference of the ATB needs to be machined, i'm not sure if you are required to do this with the locker. Best ask Ashcroft to be sure.
    Feb 2011
    Hobart, Tasmania, Australia
    Quote Originally Posted by Jazzman View Post
    Do Ashcroft arrange the machining prior to delivery? I'm surprised that they haven't modified the case sizing to suit instead.
    Free Again Thanks Dan
    I have Ashcroft Air locker pegged and yes the carrier (centre) needs to be machined to clear the pegging see attached pic`s.
    Who ever set`s th diff up should be able to do this mod in a lathe ,This is what Dave Ashcroft does so is done with his approval.
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by twr7cx View Post
    Yes you can option the centre to be machined to fit into a pegged housing. It is an option on the online website when you purchase it. As Rangieman said you could have it done locally too, but if you are going to purchase it from Ashcroft anyway it probably makes more sense to get them to do it.
