Hello all, I've got a Mitch hitch on its way to me and I'll need to get a drop ball mount to suit it. Ideally I'd like to order this before it arrives so I have both together and ready to go. I know what height I'd like the ball, but not where the square receiver is in relation to that.
Does anyone here have a genuine Mitch Hitch on an L320 RRS and can provide the height above level ground for a reference point on it (ideally the top of the square receiver hole, but pin centre would also work)? At standard 'normal' height please and advise if your tyres are standard height or not so I can factor that in.
Thank you
DiscoClax
'94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
'08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
i have one of these
Adjustable Ball Mounts
its great cause on the rrs i need to raise the ball and on the d2 i need to lower the ball.
Current Cars:
2013 E3 Maloo, 350kw
2008 RRS, TDV8
1995 VS Clubsport
Previous Cars:
2008 ML63, V8
2002 VY SS Ute, 300kw
2002 Disco 2, LS1 conversion
Thanks Tombie,
I did look at those, however,
a) very expensive, and
b) heavy, and
c) all my trailers are about the same height so I don't need the ability to adjust height incrementally. Plus they are all lightweights so setting them up to the nearest half-inch isn't critical.
I can buy a set of three forged drop mounts for less than half the cost of one of those...
Cheers.
DiscoClax
DiscoClax
No problem mate...
If a Mitch hitch on a D3 is the same height I can
measure mine ?
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
No problem mate...
Thanks LoanRangie.
I believe(?) that the rear chassis is essentially identical so the only difference should be the standard ride height and any tyre diameter effects. I'm pretty sure that the RRS sits a little bit lower than a D3, like 1/2" ish? But that might be solely in the different tyre sizes used between them? Anyone know?
If you wouldn't mind measuring yours at some point when convenient (no hurry), and advising tyre size, then I should be able to work it out from that. Cheers
DiscoClax
Mr Clax...
Knowing the unit sits directly back from the factory loop, could you not extrapolate from that point?
