                                                1st April 2018, 12:14 PM
			Axle / cv
					Hi all,
 I busted an axle the other day, Just wanted to know where the best place to buy one was ?
 I don't want to go the Ashcroft direction just yet , The axle housing is in bad shape welded up , so will get another housing an ATB and Ashcroft axles all at once down the track .
 But just to get me by until then ?
 Also how do you remove the cv joint from the axle ?
 thanks
                                                1st April 2018, 01:07 PM
					You knock the CV off the half shaft. Sometimes then can get stuck. Something a bit soft to reduce the shock from the hammer is a good idea as you can crack the CV if you hit too hard.
                                                1st April 2018, 01:54 PM
					Thanks , I gave it a few fair whacks , I thought there might be a knack ...Well I hoped there was a knack anyway
                                                1st April 2018, 02:03 PM
                                                #4
					Hold the axle in a vice and knock the inner part using a drift it helps if you have some one keep pressur on it .What spline axle?
 AM
                                                1st April 2018, 03:37 PM
                                                #5
					I use a long bit of pipe or scaffold tube a bit longer than the axle but of a size that bears on the cv then just drop the pipe and all end on , onto the cement floor. Knocks the CV off.
                                                1st April 2018, 07:39 PM
                                                #6
					Good tips ...thank you  , I will give them a go tomorrow
