Results 1 to 8 of 8
Thread: LWB 11" rear brakes, leading and trailing shoes - identification please ?
    Jul 2016
    Hi All,
    I am getting a bit confused by which shoe is the leading one and which one is the trailing one, so can someone post or refer me to a picture(s) of the rear brakes left side and right side please ?
    Sep 2012
    Westlake ,brisbane
    IMAG2005.jpg From my S2 & 2a parts book IMAG2002.jpgIMAG2003.jpg These two from 4wd's parts book.
    Jul 2016
    Thanks, but I can't say I am any wiser from looking at those diagrams :-(
    In the diagrams the shoes look pretty much the same as each other, and it's not clear whether it's a view of the right side or left side.
    Narre Warren South
    Google is your friend......
    Just found this Land Rover FAQ - 109 rear brakes
    You may find that there is no difference depending on who supplied the shoes.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Sep 2012
    Westlake ,brisbane
    Shoes
    As Gromit said the shoes could be relined the same depending on how the supplier relined them. The leading shoe is the 1st after the wheel cylinder in direction of rotation.
    Jul 2016
    Thanks Colin, Google wasn't really my friend LWB 11" rear brakes, leading and trailing shoes - identification please ?I came across the same page but I found the text "Both shoes are mounted so that the tapered end is adjacent to the wheel cylinder. The leading shoe, which goes towards the front of the car, has the lining fitted so that the distance from the wheel cylinder to the shoe lining is greater than for the trailing shoe" a bit confusing. I was going to contact the website owner (TerriAnn) for clarification, but I can't find any contact email LWB 11" rear brakes, leading and trailing shoes - identification please ?. I am going to assume the distance referred to is from slave to the TOP of the shoe linings, and that's how my old ones seem to be anyway.
    I think I know what to do.LWB 11" rear brakes, leading and trailing shoes - identification please ?
    Irymple, Victoria, Australia
    Quote Originally Posted by JohnboyLandy View Post
    I went through this a while back and from memory you need to be sure the backing plates are on the correct side too.
    From memory it changes the position on the wheel cylinder by about 6-12 mm which isn't very obvious unless you know to look for it.
    So worth checking in case a previous owner has had them off.
    Mine were 11" rears from a 109" that had been put onto the front of an 88" and were "A" about.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Jul 2016
    I did notice the backing plates were different, and hence offset the slave from the top, I wonder if gravity has anything to do with that ?
