 Originally Posted by
Silenceisgolden
				G'day all,
I removed the front drive shaft to fix an oil leak past the splines, and  noted that all four bolts have been damaged, presumably they were left  loose at some time. If I remove the flange to replace them, is it likely  that I will damage the seal to the flange?
Also, I need to buy new  nuts for the flanges and also the large nut that holds the flange to the  shaft. As near as I can judge, the four bolts are 3/8 UNF and the  flange nut is 5/8 UNC. Can anyone confirm or deny that please?
The transfer box had ATF in it - do I need to flush it to put engine oil in, or can I just drain and refill with oil?
Thanks,
Paul
 Those bolts and nut descriptions sound correct but I can check in the morning if you like. You should replace the seal if you disturb it as they have a habit of leaking if you don't. And while you have the dust shield off the drive flange  put it back on the other way so the flat side is to the front - helps keeping mud etc off the seal face. Don't bother flushing it. Just add the correct type of oil.
				Cheers......Brian
1985 110 V8 County
