Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Lithium Jump Starters
    Jul 2016
    Blackstone
    A while back I bought a Micro-Start XP-10 Jump Starter.
    I have used it on my Mazda 3 and it worked.
    Today I was working on the D3 with the stereo on, but didn’t realise that the air-con fan was running. So dead battery. Wouldn’t turn over. I could have used the auxiliary battery but decided to try the jump starter.
    Was sceptical but it worked. Didn’t kick over like a starting battery of course but did the job.
    Jan 2017
    Geraldton WA
    When I first tried one of these out I was VERY Sceptical But I had No dramas at all starting a Hilux 4 cyl diesel. For their size these things pack quite a punch
    4.6m Quintrex boat
    Mar 2007
    Warwick Qld
    I bought a cheap one as a power pack for the phone etc. Was very pleasantly surprised when it jump started a Barina that could barely wind itself over!
    Ain't modern electromagical stuff bloody marvelous!
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Nov 2014
    My mate with a 2.7L D4 had a completely flat battery and the RACV guy needed to use two of these packs to get it started.
    Mike
    MY14 TDV6, ARB Bar, Fyrlyt's, 18" Compomotove Rims. 265/60/18 BFG KO2's, Front Runner roof rack, removable rear false floor.
    Jan 2015
    Goulburn
    Battery Jump Starter Pack
    We are off to the snow for a week but the combined draw of the Traxide dual battery system and a Haltek performance chip is around 250ma until the Traxide timer reduces the draw from the smart switch.
    I am not sure how long the battery will hold enough charge to crank especially as it will be parked in the open and I will not be able to charge it. Hence I was thinking of buying a battery Jump Starter pack as Insurance or use the Ctek MXS 15 in Supply mode if the battery does not crank the motor, as I should be able to plug in the Ctek to start the car. The alternative is a jump start pack, but it looks like I would need a pretty big one given the cold cranking amps required.
    I usually charge the battery around every 3 or so days in the colder months as we do mostly short trips. We live in (cold) Goulburn!
    A jump start pack could be useful outback but lugging one around all the time, plus the cost (over $300 from Super Cheap) are an issue.
    Sep 2014
    Baldivis WA
    About 2 years ago one of those lithium jump start packs could not crank over the 3.0L D4 despite being fully charged. I now carry a Black and Decker 350cca (Nominal) jump starter in the camper when we are out bush.
    I believe these lithium jump starters are better now
    Jul 2013
    My old man got on a while ago. Had to use it last year to start my Suburban which had a flat battery - it fired up the big block 454 perfectly.
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Mar 2018
    Perth (near Malaga)
    Most of them (like all the ones I've looked at) work by putting a very fast surface charge on the battery. Works great for a good battery gone flat, but not so much for a genuinely dead starting battery (like dropped one or more cells/high internal resistance).
    I do the same thing with a ryobi one+ 18V battery. Put it in series with a 55w headlamp bulb and onto the dead battery. The headlamp bulb provides enough resistance to stop the ryboi tripping out on overcurrent and quickly puts a surface charge on the car battery. I always have at least one ryobi battery in the car.
    Sep 2012
    Adelaide Hills
    ive found these jump starters dont last more than a year or 2
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Jul 2016
    Blackstone
    I’ve used mine a number of times now. If you get in the vehicle and there is enough charge to just turn the engine over then it works fine. Try starting once if it fails connect the jump starter. I haven’t used it on a really flat battery but I don’t think it would work.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
