Results 1 to 10 of 25
Thread: Dash lights stay on with key out
    May 2008
    Bundaberg Qld
    I recall a thread on this recently but cannot find it.
    D2 TD5 will crank but not fire and the dash lights stay on after key removed.
    Any clues
    May 2008
    Bundaberg Qld
    Bump
    Jul 2014
    west of Transylvania
    When it does that unplug the brown 6 pin connector which is plugged into the front right side of the interior fusebox and if the lights go out this way the problem is most probably in the ignition switch...if no joy we'll speak then
    btw do you have some additional brake controller or something wired into that fusebox
    May 2008
    Bundaberg Qld
    I am going to put a new battery in it first but yes it has a brake controller, UHF and turbo timer all wired into a bit of a rats nest.
    May 2008
    Bundaberg Qld
    New battery fitted. Fault still occurs and the lights go out when the brown plug is removed.
    May 2008
    Bundaberg Qld
    A few more clues in the puzzle.
    In removing the brake controller from the rats nest under the dash, I noticed that when pulling the keys out, the ignition lights still stayed on but longer than usual (was about a minute previously). I also noticed that I had bumped the turbo time switch to 5 from 1 minute. Went through the key in/out routine again, timing the ignition lights this time they matched the turbo timer switch position.
    With the turbo timer now removed the ignition switch and lights appear to function correctly.
    So the state of play ATM is that the car will not crank (or logically fire) using the key. When moving the key to the start position, the fan drops off and a relay (?) can be heard operating under the dash. It will however crank (but not fire) when I hot-wire the starter motor. Does this indicated immobiliser issues ??
    DiscoMick Guest
    I remember at one stage the switch on the auto in our D1 which prevented it starting unless in Park failed and the vehicle would crank, but not fire. Not sure if that is related to your problem.
    May 2008
    Bundaberg Qld
    Another clue (if it helps at all) is that the car locks and unlocks using the remote on the key.
    Have you checked the inertia switch on the firewall in the engine bay? A simple press on the top will tell you if it’s been tripped.
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    Mar 2015
    Horsham Victoria
    Before you removed turbo timer,with key on did you push the red button then try to start, although now it's removed the point is probly mute.
