Thread: Leaves caught under mudguard
    Nov 2017
    Has any one had the problem of leaves being caught under the mudguards? They get down the drain channels under the bonnet (see picture). Any idea on how to remove them?Mudguard.jpg
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Discoveryncc1031 View Post
    Has any one had the problem of leaves being caught under the mudguards? They get down the drain channels under the bonnet. Any idea on how to remove them?Mudguard.jpg
    What car? Might be best to post this in the appropriate section.
    Mods?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2003
    On The Road
    clamshell bonnet,, so---
    Sep 2010
    The Hills.
    152.79 MB
    Do I look like a clam? No, don't answer that. How about putting your mod hat on and moving it????
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    St Helena,Melbourne
    1.13 MB
    D3 or 4, only way to get them out is to remove the plastic inner guard.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Moved from Rules and Guidelines.
    Sep 2014
    Baldivis WA
    I recently replaced all four mudguards after I found that all four steel brackets in the mudguards had rusted out. When removing the old mudguards I found the area behind them and up inside the guard filled with (dry) leaves. An old plastic coated steel coat hanger allowed me to get it all out. Can’t do much about getting them back in, but I will be checking behind the mudguards every 6 months, oh and not parking under trees...
