Results 1 to 8 of 8
Thread: TD5 Motor, cold Motor??
    Feb 2005
    Noticed on my recent trip that on cold mornings/weather (single figure temps) it didn’t want to warm up. I had to run a gear lower for a long period of time to get the engine temp up.......mainly to get some benefit from the heater.
    Silly me didn’t think to plug the Nanocom in to get actual temps.
    Soooo, are the a cold running motor or do I need to investigate a bit more.
    Melrose SA
    I would suspect the thermostat mine always heats up quickly
    Free Again Thanks Dan
    Mine in city traffic takes for ever to heat up .
    On the open road it warms up in no time .
    I think it all depends on driving circumstances
    I would say in the bush it would take a while to warm up unless you are working it hard ect low range steep climbing for a while
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by djam1 View Post
    X2
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Oct 2013
    Richmond, NSW
    I live in the country and owned my td5 ute from new (1999) and drive the same route most days. In the summer it takes around 3kms on a windy dirt road at 50kph for the temp to start rising. In the winter when it can get to -5 it can take as far as 5kms to start to move and upto 6kms to start to feel any heat. Its no different now from when it was new. :-)
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Avoca Beach
    Just check the connection of the connector on the sensor before you do anything else.
    The Nanocom also runs off the sensor so if the connection is dirty it will read low.
    It's pretty common and happened to me.
    Regards Philip A
    Feb 2005
    Regards Philip A
    Thanks for the tip, where is the temp sensor??
    Avoca Beach
    It is on the housing where the top radiator hose leaves the engine.
    It has an injector connector, so just squeeze the little metal bar and pull it off, spray it with some electronics cleaner and click on and off the connection a few times.
    Regards Philip A
