Results 1 to 4 of 4
Thread: fuel gauge issue
    Sorrento Victoria
    fuel gauge issue
    My fuel gauge has been very temperamental/unreliable. yesterday i drained the fuel tank as lot of crap in sedimenter -i also removed sender unit to inspect and all looked okay with wiring/connections -put it all back/ reconnected wires at tank and now my gauge doesn't even move off empty even though almost full-when i removed positive lead at tank the gauge went to completely full-what's the deal with that-bad earth?
    Nov 2015
    Victoria
    Quote Originally Posted by mattmac View Post
    My fuel gauge has been very temperamental/unreliable. yesterday i drained the fuel tank as lot of crap in sedimenter -i also removed sender unit to inspect and all looked okay with wiring/connections -put it all back/ reconnected wires at tank and now my gauge doesn't even move of empty even though almost full-when i removed positive lead at tank the gauge went to completely full-what's the deal with that-bad earth?
    My perentie decided to read a max of 3/4 tank a while ago. While I havent yet investigated why, I'm led to beleive that it's common for the float to fill with fuel.
    However with lucas wiring, bad earths are a real possibility, as are rotting push connectors.
    Jan 2016
    Lane Cove
    gauge
    Thats worrying as when you remove the positive it should read empty and when you ground the positive ( not through the sender ) it should read full.
    I suspect the gauge itself may not be effectively earthed - it needs to be.
