Results 1 to 10 of 12
Thread: Front shocks
    Hunter Valley
    Front shocks
    Hi. A friend on mine has a td5 that is fully loaded for touring. He is having trouble with the front shocks not having enough damping on rebound on corrugated roads. He has had the crash switch trip a few times when the front axle tops out he has new bilsteins on the front. Any suggestions on a shock that would better suit. It has a steel bar with winch. Thanks
    It doesn't leak oil, Its sweating power
    Jan 2017
    Geraldton WA
    It may be the springs that are the problem.
    4.6m Quintrex boat
    Oct 2014
    Bundaberg, QLD
    Did he replace the springs? they may be sagging and not holding the weight of the vehicle causing the shocks to take more of the load
    2000 Discovery 2 td5 Auto (Sandy)
    2" dobinsons springs and bilstein shock,
    Arb steel winch bar, homemade rear drawers,
    steel rear bar
    7" Led spotties, Roo systems awning, 3 cross bar roof racks
    265/70R16 Falken Wildpeak AT3W
    Oct 2007
    Brisbane West
    Not sure what his set up is. I have put my d2 at GVM through horrid currugatated roads (including Cape York) at speed with Dobinson springs and Bilstein single wall.shocks and it was absolutely magic at all times...Cheers
    Hunter Valley
    Thanks for the replies. He has new springs raised 50mm. Unsure of brand but were supplied by Triumph Rover spares. They're red in colour. The way he explains it he has no problem on compression but is terrible on rebound and is only with the front.
    Jan 2017
    Geraldton WA
    My springs and shocks are bog standard on my D2a with an ARB winch bar, winch and about 10kg of spotlights/lightbar on it and I don't have any dramas off road with it.
    4.6m Quintrex boat
    Apr 2016
    Country Vic.
    Quote Originally Posted by woko View Post
    ..... He has had the crash switch trip a few times when the front axle tops out he has new bilsteins on the front.....
    Thanks for the replies. He has new springs raised 50mm. .... The way he explains it he has no problem on compression but is terrible on rebound and is only with the front.
    I'm no suspension guru .. or even know the second thing about suspension, and assuming that the bilsteins aren't the +2" types:
    if he has raised lift front springs, and didn't use +2" front shocks(or dampers to use the correct term), then wouldn't the shocks take all the loading on full extension of the springs?
    That is, the shocks are 'topping out'.
    longer springs = more travel in most cases .. so the shocks then take the full force of the spring when extended.
    Confirm with him if the shocks are extended types or normal.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Hunter Valley
    Quote Originally Posted by AK83 View Post
    Shocks are 50mm longer aswell
    Apr 2016
    Country Vic.
    Ah! OK then.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    May 2009
    Front shocks
    Get them valved with more rebound?
    There is usually someone in the major cities, Baker bros in Melbourne.
    If they are new it may also be a warranty claim.
