Results 1 to 8 of 8
Thread: Need an ECU
    Australia
    Need an ECU
    For some reason I started up today and moved out of the car park, spluttered cleared and spluttered again.
    Plugged in Nanocom and ECU thought it was overboosted.
    Clear faults but no joy and then no more comms with ECU.
    Swapped the ECU out to mates D2 and same issue.ie the fault remained with the ECU and symptoms then displayed on mates car.
    No comms and stupid thing is randomly switching the fuel pump on/off along with indications of glow plugs and MIL.
    Its not an oil in the plug or ECU related issue.
    The ECU is misbehaving and best I can understand, thinks its in an overboost state from the outset.
    So anyone with a NNN000130 or NNN500030 ECU please let me know. I have posted in wanted also.
    Feb 2005
    If there was no change when you swapped ECU’s than would this suggest the problems is elsewhere?
    Australia
    I should edit my post The problem went with the ECU over to mates car.
    Nov 2014
    Nirvana near Albany W.A.
    no oil , moisture , obvious damage to circuits ?
    Australia
    Quote Originally Posted by discorevy View Post
    No, spotless and dry inside.
    Feb 2005
    Quote Originally Posted by strangy View Post
    Whoops, I looks like I didn’t read it right
    Nov 2007
    Townsville Nth Qld
    I have a spare one is it manual or auto
    Australia
    Auto
