Results 1 to 6 of 6
Thread: D3/RRS Drivers Door Window - One touch up.
    The one touch up function on my drivers door window has stopped working. The window will go up if I hold the switch up and will go down using the one touch function and the passenger window works as it should.
    So is the one touch function controlled via the switch or is there a controller somewhere that just takes the one touch signal from switch and then works the door window? Any ideas appreciated.
    Now not sure it is relevant but the other day I left one of the map lights and the cubby fridge on over night and had a flat battery (10.7v) - enough to still work ancillaries like the windows, radio and central locking but not enough to start the car. Jump started the car and all is good now - I did a hard reset just in case the window issue was a left over from the flat battery but made no difference.
    Ideas??
    Hunter Valley
    You will need to reset the windows. Try this
    1. Put window all the way down.
    2. Put window all the way up, and release.
    3. Hold "up" for 3-5 seconds.
    It doesn't leak oil, Its sweating power
    1.13 MB
    ditto
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Thanks for both of you for the information but I must have done that accidentially.
    Just after I put up the post I went to go down to the shops to get my pizza for dina and the window was working and it had not done so for a couple of days.
    garry
    1.13 MB
    I know you have to reprogram the windows after a CCF change but there may be other conditions that reset it as well. Anyway it's an easy fix.
    Rod
    May 2010
    Brisbane, QLD, Australia
    Quote Originally Posted by rocket rod View Post
    Disconnect the battery or have a battery failure .. simple fix. :-)
