                                                21st April 2018, 11:45 AM
			ABS-Traction Control lights stay on?  Found a cause
					A cheap and quick check before you start diagnosing a problem. One of two blade plugs on the filler cap of the brake reservoir had worked its way loose. Once refitted the lights on the dash went out and stayed out.
 I must have knocked them loose while cleaning the area.
 New Zealand
 2008 Puma 110
