Might be a bit lonely here
I thought I's star this thread as now that I own a Freelander 2 I'm going to be quite busy with it over the next few weeks getting the car registered in Victoria.
So far I have ordered a new rear light assembly as the one on the car is cracked and will fail the roadworthy. I tried to re aim the windscreen washer jets and the needle, as recommended in the owners manual broke inside the jet. I now need to order one of these, part number L2002264. Or could I swap the one on the D2 over? They look the same to me.
Julian
Build date 11th Oct 2003
LROCV #1410
LROCV #1410
I picked up the windscreen washer jet from MLR Port Melbourne and installed it on the car. I lost one of the trim clips that hold the acoustic panel onto the bonnet. Some thing else to buy.
LROCV #1410
The car has gone in for a road worthy. I know that the rear driver's light will fail. MLR did not get this to Port Melbourne on Saturday. It will arrive today. I'm hoping that every thing else is ok, or easy to fix.
Julian
LROCV #1410
That is what is wrong with the car. How easy is it to replace the rear mount on the front control arm.
Ta
Julian
LROCV #1410
Easy fix at $1,000!! it goes ti Vic roads for it;s rego on Friday.
LROCV #1410
Yes, it's true the car was registered in Victoria this afternoon.
LROCV #1410
The car has an Anderson plug on the rear on the trailer plug mount. No voltage at the plug! With the engine running or not.
LROCV #1410
