Thread: Auto Trans ZF 4HP 22 and 24
    Oct 2011
    Fremantle WA
    Anyone happen to know if the 4HP22 and 4HP24 auto transmissions sump pans are the same size meaning will a 4HP22 sump fit/bolt straight onto a 4HP24 please? If not, I've just made up a fitting for a trans temp sensor that I wont be able to fit to my 24.
    Nov 2014
    Nirvana near Albany W.A.
    It'll fit Gavin
    Oct 2011
    Fremantle WA
    Quote Originally Posted by discorevy View Post
    It'll fit Gavin
    Phew .
    Heading your way leaving Freo Sun 6th towing the brick, so will call you early but later in that week.
    May 2003
    On The Road
    Oct 2011
    Fremantle WA
    Bugger/Oops!
    I was in the bush and received 2 pics to show what had been done - guess what, I deleted them this morning and the sump will by now be fitted.
    Basically, I had a small extension section welded at the back of the sump, to which the retaining nut was welded, and the sensor screws in horizontally from the back, protecting it from damage.
    Canberra, Australia
    Gavin,
    Certainly sumps will swap ... fitted a 22 sump with dip stick to the 24 on my sons D2.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Oct 2011
    Fremantle WA
    Thanks all. Yes did fit.
    Only minor hassle was that I forgot replacing the D1 pan in the D2 with the original and modified D2 pan meant that I had to take out my ATF dipstick, as the D2 pan only has the filler point, not a connection for the D1 dipstick.
    Oh well, will eventually come up with a solution for the best of both worlds.
