Thread: factory winch Cradle
    Unison Guest
    I have a 99 p38 and found a range rover brocure from the same year. It has all the extra options u could order.
    Including the factory winch cradle. If only u could still order .
    Does anyone have one ,seen one ?
    My question is .... how was it mounted to the chassis?? im imaging the 2 bolts on both chassis rails behind the crush cans . posts on here say these have failed as a spot to mount a recovery point . ie there to close to the end of the chassis rail and have pulled through. so did they use these bolt holes for the winch cradle??
    Paul
    I saw one at my local shopping centre - I have a pic if I can find it.
    If you have a copy of RAVE, look at the Accessory Fitting Instructions. Here are a couple of pages from it:
    Unison Guest
    thanx
    yeah sweet thanx .
    what is rave?? looks awsome .....can u scan the next page ?
    so the 10mm bolts get changed to 12mm and there is a few brackets that get bolted on .
    Feb 2013
    Gosford, NSW, Australia
    Rave is the PDF version of the workshop manual
    You can grab a copy from the first link on this page
    Range Rover Projects and Information
    Steve
    Rover (I think) Aftersales Viewing Environment
    Nov 2008
    Bruthen, Eastern Vic.
    Rover do have a sense of humor after all.
    Terry
    Sep 2013
    Darwin
    12.74 MB
    Quote Originally Posted by rover-56 View Post
    Terry
    Repair Add Value Enjoy?
