Results 1 to 10 of 11
Thread: D2 fuel pump Blowout. Why ???
    Apr 2018
    Blampied
    70.89 MB
    hi folks. cut a long story short. bought a D2 td5 from deceased estate.
    sold for parts as it had been cooked by the kids. top end beyond repair.
    currently awaiting delivery of an engine i bought from Dazza of aztec 4x4 in w.a.
    apart from all the other stuff i have to do , pre new engine, i decided to check out the fuel pump yesterday.
    while turning over the origional motor it was making horrible noises.
    removed it and look what i found. !!
    the pipe from the pump has exploded for some reason.
    any ideas. ??
    Nov 2014
    Nirvana near Albany W.A.
    blocked fuel filter is the main cause , usually ( but not always ) combined with low fuel levels ( which makes the return fuel hot )
    Apr 2018
    Blampied
    70.89 MB
    Quote Originally Posted by discorevy View Post
    thanks for comment.
    but, fuel tank is full.
    pump filter was relativly clean. some dirt / grit in about 1/4 of bottom screen.
    Jan 2014
    Perth Western Australia
    Just replace the pump assembly with a new VDO and it will be good for about another 10 years.
    Yes engine should be just about there, will chase it up Monday.
    I always recommend changing fuel filter every 10K service.
    Daz
    NSW far north coast
    Daz, do you and Revy have any preferences re the fuel filter on the TD5?
    I've only entertained Mahle, Mann and genuine so far, and interestingly one repairer I picked some bits up from recently will only use genuine.
    I would've thought Mahle and Mann would be ok too?
    Jan 2014
    Quote Originally Posted by rick130 View Post
    The only one I stopped using many many years ago was COPPER, as they seem to have this habit of blowing the bleed screw off.
    So yes, Mahle, Mann, Baldwin, Genuine, and I've got some Bearmach ones that are made by Mahle.
    Daz
    Apr 2018
    Blampied
    70.89 MB
    Quote Originally Posted by DazzaTD5 View Post
    hi dazza
    ordered a new vdo unit yesterday. :-)
    out of curiosity i 've just tried out the fuel pump in bucket of diesel.
    purrs like a kitten !!
    is it possible to get replacement ribbed hoses at all ??
    could rebuild and use as spare !!
    Nov 2014
    Yep, Mann, Mahle and genuine , I've also used Filtron (wix) , may or may not have had trouble with a COPPER for many years
    Jan 2010
    Quote Originally Posted by gofer View Post
    hi dazza
    I'm sure some people on here will have old fuel pumps lying around, that you could use the hoses from, possibly a "wanted" ad is all that is required. I used Coopers on my D2 TD 5 without bleed screw trouble, and only stopped using them as they don't seem to be bio-diesel compatible.
    Apr 2018
    Blampied
    70.89 MB
    Quote Originally Posted by RANDLOVER View Post
    hello randlover.
    thanks for comment.
    i've come across a few old posts about fuel line.
    FHIT8 is the type of submersable hose.
    5/16 is the internal diam.
    must be rated R10 ( SAE 30R10 ).
    regards "wanted " add, its a thought, but i would imagine that most of the "2nd hand " tubing would be just that ! "2nd hand ". haven't found any new ribbed pipe on internet yet.
    i think the pipe becomes brittle with age . haven't tried to remove my pipe yet.
    will try hot air gun and see what happens.
    gofer. :-)
