Dum Dum putty was stuff I was thinking of, but alas it seems not available these days.
modern alternative seems to be 3M Strip Caulk
Anyone where to get moldable cable putty, for use as an alternative to rubber grommets?
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
Electricians use a putty, I think it’s has fire retardant properties as well.......
Although houses don’t go over vibration for 100’s of Km’s
HS2.8 TGV Powered
Sikaflex my be better than putty![]()
4.6m Quintrex boat
Our mobile auto electrician used some stuff called tacky tape. Rip off the backing, then stuff or wrap. It self fuses. Hack through it with a knife to get it off.
Don.
Is it because you can not get in to the location to fit the grommet?
If it because you need something of variable size try “Grommet Strip”
