Results 1 to 10 of 11
Thread: Are 9 speeds too much?
    Apr 2018
    Victoria
    I don’t like transmissions that hunt around constantly.
    Is the 9 speed so imperceptible that you don’t notice all the changes?.
    What minimum speed gets you into 9th?.
    99.87 MB
    Slunnie
    Dec 2011
    Bundeena
    Personal experience is the 9 speed is fine - just like the 8 speed in the larger vehicles. It doesn't hunt at all. The extra gears just means the car has a broader choice available to ensure optimal engine torque and power are available and for that reason would help to avoid hunting.
    Sean
    Apr 2018
    Victoria
    What speed do you have to reach before it goes into 9th?.
    Dec 2011
    Bundeena
    Quote Originally Posted by Nagaman View Post
    I'll have to check. It's my wifes car so I won't have the opportunity until the weekend. Don't forget, the engine specs will also dictate when the gear changes will happen. Engines with lower torque/power output will be more likely to use the lower ratios more often.
    Are you asking because you are looking to buy or do you have one already?
    Sean
    Apr 2018
    Victoria
    Quote Originally Posted by SBD4 View Post
    I’m definitely in the market.......it’s just a matter of time and there is the update coming which makes it even more interesting. A higher info ‘screen’ would be an improvement from my perspective.
    Dec 2011
    Bundeena
    Excellent! What spec trim/engine are you aiming for?
    Definitely be sure to get what you want. Too much money being spent to have regrets. Buying my RRS was a bit of a rush. Consequently there are things I missed out on that I really regret not having.
    Sean
    Apr 2018
    Victoria
    I’m looking to buy an SE and the basic diesel is fine . I don’t intend to get sucked into expensive options either.
    Kingston, Tassie, OZ.
    More torque = no hunting around for gears😎
    Dec 2011
    Bundeena
    This information is probably a bit more like what you are looking for. You can see below that at 1000 RMP in 9th the car will be doing 72 KPH. when doing 100Kph the engine will be sitting at just under 1400RPM which it will do very comfortably (SD4 420nm/140Kw). As Justin said above, the more torque the more inclined the engine will be to use a higher ratio at a lower RPM:
    Gearbox: ZF 9HP48
    Transmission type: automatic
    with CommandShift manual shift mode
    Number of gears: 9
    Gear ratios (overall):
    I 4.7 (18.54)
    II 2.84 (11.2)
    III 1.91 (7.53)
    IV 1.38 (5.44)
    V 1 (3.94)
    VI 0.81 (3.19)
    VII 0.7 (2.76)
    VIII 0.58 (2.29)
    IX 0.48 (1.89)
    X ()
    R 3.81
    Speed range
    (max speed on gears,
    top gear value theor.): (km/h/mph)
    I: 33 / 21
    II: 55 / 34
    III: 82 / 51
    IV: 113 / 70
    V: 156 / 97
    VI: 192 / 119
    VII: 223 / 139
    VIII: 269 / 167
    IX: 325 / 202
    X: /
    1000rpm speed: (km/h/mph)
    I: 7.4 / 4.6
    II: 12.2 / 7.6
    III: 18.1 / 11.2
    IV: 25.1 / 15.6
    V: 34.6 / 21.5
    VI: 42.7 / 26.5
    VII: 49.5 / 30.8
    VIII: 59.7 / 37.1
    IX: 72.1 / 44.8
    X: /
    Torque converter factor:
    Final drive ratio std: 3.944
    Sean
