Thread: Half shaft bearing (244150) - need to be packed like wheel bearings ?
    Jul 2016
    Hi All, just wondering if this bearing needs to be packed, or is it lubricated from Swivel oil ? It's on the outer side of the axle seal, so presumable diff oil wouldn't reach it.
    JDNSW's Avatar
    Swivel is filled to above the bottom of the race, so not needed (but won't hurt, especially if it is likely to be left for some time before filling the swivel, to keep moist air off the bearing).
    Jul 2016
    Excellent, thanks John !!
    Hobart Tasmania
    Also, on the same topic, can one grease pack the bottom bearing and race on assembly and railko pin/bush so not installing dry?
    Carlos
    1963 Land Rover Series 2a 88
    Narre Warren South
    I guess so, the grease will go into solution with the EP90.
    Personally I used EP90 and a paintbrush (reserved for use with oil) and 'paint' everything inside the swivel hub, especially if it will be standing for some time before used on the road.
    I also have an oil can filled with EP90, easy to squirt some EP in before you install the stub axle.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Cap View Post
    I did on mine just for a bit of overkill, but the book didn't say to do it, so I guess it's not critical.
    Hobart Tasmania
    Good idea about lubing the inside of the swivel... mine isnt going to be ready to use for quite some time so ill use that idea!
    Carlos
