Faulty temp sensor?
Try here: LPG Diagnostic Software
For whatever reason my D2a sequential Dream XXI? is now switching to LPG nearly straightaway after starting, at this time of year this naturally leads to missing on a few cylinders,,
Is there software available to change this?
any pics/numbers for the laptop adaptor?
is there a recommended temp for this?
Faulty temp sensor?
You'll also need a tuning cable, avoid generics as they can brick your ECU. Genuine AEB is recommended. I usually set change over around 50C to 60C, gives it time to get the system into closed loop mode. Alternatively, just run it manually on petrol for a couple of minutes every morning.
KING AEB 001N USB Interface Diagnosic Lead
An adaptor is available for early model diagnostic plugs.
AEB STAG OMVL Dream N-E Adapter
