Thread: Double Cardan Query
    May 2015
    Williamstown, Victoria
    Double Cardan Query
    I'm assuming that the output of the transfer case is parallel to the input of the front diff. Yet the transfer case has a double cardan joint, to allow a wide range of movement. Surely the same wide range of movement occurs at the diff end, with only a standard universal joint. If the axes of the transfer case out put and diff input are parallel that the angle changes at both ends will be identical. So why a double cardan only at one end? What am I missing?
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Avoca Beach
    IMHO the double Cardan is primarily to decrease vibration.
    A Hooke joint does not travel at a constant speed , it slows and quickens 8? times on each revolution.
    2 Hooke joints means twice the speed change =vibration.
    The double Cardan reduces the speed differences particularly at larger angles.
    Regards Philip A
    Mar 2015
    Perth, WA
    The output of the transfer case is near to vertical and the input to the diff is not that near (it is closer to inline with the shaft, but also not exact) so the double joint is to remove vibrations from angle mismatch rather than allow extra movement.
    Jun 2011
    Victoria - Pakenham
    As far as i understand, it is a double cardan joint because the shaft is short therefore the angle is greater than, say a Toyota Land Cruiser. With 2 uni joints the angle is split between both joints, each taking half.
    Best analogy I can think of is using 2X 45 degree drain pipe fittings to make a 90 degree bend.
    This then deduces the vibrations and stress on the uni's because they don't have to bend / twist as far on their vertical plane.
    Crafers West South Australia
    The reason that a double cardan joint works to reduce vibration is because the two joints almost exactly cancel out each others speed variations.
    Link with animated pictures:
    3D CAD Model Collection | GrabCAD Community Library
    Kilmore, VIC
    106.38 MB
    Yep, Bee Utey is spot on. A double cardan is classified as a CV (Constant Velocity) joint because of this.
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by Bohica View Post
    Julian
    They're actually not parallel. Without lift the front diff flange it 90 degrees to the ground, but the front output flange on the transfer case is pointing to the sky slightly. If you've got a broken rear rubber mount it is even worse.
    Once lifted the front diff flange points towards the TC but the front output flange is still in the same position. Very over exaggerated the flanges look like this after a lift DIFF \/ TC. Before a lift Diff |/ TC. Not || as you would expect.
