 Originally Posted by
Chanoo
				Thought I'd give you all my experience and thoughts on a head replacement for the td5 defender
This all began with getting diesel in the coolant, so two possibilities 1. The fuel cooler 2. cracked warped head
After isolating the fuel cooler to eliminate that avenue, was still getting diesel in the coolant.
So I bit the bullet and took it in for a head replacement
New aftermarket head, all the gear to go with it gaskets, bolts, ect. Also got the starter motor reconditioned (it was stuffed).
6 days in the shop,
All put back together, had  an issue of what they suspected was over fueling but turned out to be faulty connection for the air flow meter. So all is good now
The final cost was  $4960.60
Once I had told the boss of the cost and let her cool down for a few days all sweet.
Although another major expense for the defender and it will be goodbye (the vehicle not the wife).
Was apprehensive in the lead up to getting the work done but once the decision was made to do the work, was feeling much better and made the correct decision.
