Results 1 to 9 of 9
Thread: New ignition key
    david7307 Guest
    New ignition key
    My ignition key will lock my doors but pressing the open button nothing happening. Took key to bits and found a bit broken off the circuit board. So now when i unlock with key in door the alarm goes off
    Where can i buy a new circuit board or a whole new key .or can i buy second hand and get it programmed to my disco. or can i disarm the horn
    If it’s the little button that’s broken off - you can get a kit on eBay. Solder the new bit on and fit in the new case.
    david7307 Guest
    If itz the little button on the circuit board . i have get that bit so just solder that back in place .many thanks
    Avoca Beach
    Jaycar has them.
    maybe different shape but do the job.
    Regards Philip A
    Feb 2013
    Queensland
    If you got a genuine new key remote how do you program it to your car.
    Avoca Beach
    • If you got a genuine new key remote how do you program it to your car.
      There should be a piece of paper stuck to the circuit board with a code on it.
      A Nanocom can then be used to add this code to the codes in the ECU.
      Regards Philip A
    Feb 2013
    Queensland
    Can it be done with a hawk eye
    Jul 2014
    west of Transylvania
    Quote Originally Posted by laney View Post
    Hawkeye will work only with the long barcode supplied with new keys not with the short one from inside, i've seen posts where the code generator worked but i've tried twice with hawkeye without success so it's a lottery, i mean this: disco2_fobcode_2_Barcode.xlsx
    DiscoS1 Guest
    I had the same problem when i bought my D2, I bought 2 switches from jaycar cost 1.90 soldered them. Fixed it but it tends to only work when the key is right next to the car window but hey better then the alarm going off every time. Also better then $700 from Land Rover or $300 for something from the UK options.
